Dear experts, please, help to solve the problem related to the connection to the web GUI of F5 through the SSH tunnel with enabled port forwarding feature.
The reason why I need such thing - our external F5 is located in the DMZ zone and has totally another subnet.
Tunnel works, port forwarding for the 443 port also works.
Problem is when login like https://127.0.0.1:1212, F5 web gui successfully shows me login page.After this I input the login and password, submit them BUT after this I see redirecting procedure in the browser and as a result empty error page in the browser.
So I need to know for what kind of port need to make forwarding in the SSH tunnel to access F5 web gui successfully?
For internal F5 for debugging reasons checked netstat -an | grep (IP from which I establish connection) output in the F5 console when I connect to the direct IP of the BIG-IP device and see that during browsing F5 web gui there re a lot of connections to 443 port and that`s ok.
So I don`t understand the reason why the page in the browser after logging to the F5 outputs standart:“IE cannot display the page” error.
So I need to know for what kind of port need to make forwarding in the SSH tunnel to access F5 web gui successfully?it works fine here. i only configured local port forwarding to bigip port 443.
this is my post request/response header.
POST /tmui/logmein.html? HTTP/1.1
Accept: application/x-ms-application, image/jpeg, application/xaml+xml, image/gif, image/pjpeg, application/x-ms-xbap, application/vnd.ms-excel, application/vnd.ms-powerpoint, application/msword, */*
Referer: https://localhost:1212/tmui/login.jsp
Accept-Language: en-US
User-Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; InfoPath.3; MS-RTC LM 8; .NET4.0E)
Content-Type: application/x-www-form-urlencoded
Accept-Encoding: gzip, deflate
Host: localhost:1212
Content-Length: 27
Connection: Keep-Alive
Cache-Control: no-cache
Cookie: JSESSIONID=B8B62933251093015F0045B31C1648F7; f5advanceddisplay=""
HTTP/1.0 302 Found
Date: Sat, 18 May 2013 13:29:38 GMT
Server: Apache
X-Frame-Options: SAMEORIGIN
Set-Cookie: BIGIPAuthCookie=E478E0591018427D1E412AC98E779A490A83CD0F; path=/; Secure;
Set-Cookie: BIGIPAuthUsernameCookie=admin; path=/; Secure;
Content-Encoding: gzip
Content-Length: 164
Connection: close
Content-Type: text/html; charset=iso-8859-1
