I tried to understand through the official F5 link below, but there are still a few questions I would like to ask
1. If I just look at the throughput of the client coming in to F5, the service value and In value of Throughput is not there, right? Should I be looking at the file with the In values for the TMM client?
2. What is the meaning of multiplying 8 within the formula? Why is it multiplied by 8 ?
1. That article is pretty good at explaining.
The traffic flow from a client is seen as In to a virtual server and In to a server. Likewise, the response from the server is seen as Out from the server and Out from the virtual server.
Client IN → Server IN
Client Out ← Server Out
2. Because the counters are in bytes example sysStatClientBytesOut , to convert it to bits , it is multiplied by 8. Because a byte has 8 bits
3. The counters have predefined intervals , like this for example:
The total throughput in and out of the BIG-IP system collected from all interfaces, including traffic processed by all Traffic Management Microkernel (TMM) and Packet Velocity ASIC (PVA)
In: The ingress traffic to the system through its interfaces
Out: The egress traffic from the system through its interfaces
In : means total ingress traffic on all interfaces except management.
You are comparing the value of 208 K which is all ingress traffic on all interfaces
with a Value of 28K that something IN and something OUT.
What are you trying to do? I don’t think adding things will give you something that you’ll expect.
That’s because of different things that affect the throughput. See below.
Have a look at the number of packets IN and packets OUT. You will see that you have more than twice the number of packets coming in than going out.
I don’t think it works that way. you have throughput in and throughput out.
Also be aware of different options that affect the throughput, like oneconnect, HTTP cache, compression, irules
