About the load-aware algorithm.
Hello Everybody
The load-aware calculation that the BIG-IP performs for each device is:
(The sum of local active traffic group loads + The sum of remote active traffic group loads) / device capacity
The "The sum of remote active traffic group loads"is what?
This link not presented clearly.
Many thanks
active traffic group loadsas i checked, load is number of traffic group unit is handling.
there is request for enhancement ID392172 to include other factors.
ID392172 - RFE: automatically include %CPU use, memory and throughput in device capacity measure
Thanks nitass
Can you detailed instructions about load-aware algorithm?
For example:
The sum of local active traffic group loads: This device all the traffic group of HA Load Factor sum of the values​​.
Device capacity: HA Capacity value for this device.
The sum of remote active traffic group loads:what this?How to set up or view?
Thanks again.
lee
Can you detailed instructions about load-aware algorithm?isn’t it in “Implementation Results” section of link you posted?
Manual Chapter: Configuring Load-aware Failover
