About SLL offloading
What is SSL Offloading and what is the use
Hello Lingesh, it’s basically a process of transferring or moving SSL processing from a system to another system. In relevance to F5 and web servers, if you want to remove the burden of SSL processing (encryption/decryption) from your web servers then you offload it to the F5.
