About SIP Notify
Hi Guys,
When I use [SIP::header value NOTIFY] in iRule, F5 shows following error, would you please happen to know the reason why? thanks.
Rule [SIP_XXX] error: line 30: [Invalid syslog level - bad priority: NOTIFY] [log local0.NOTIFY ${[SIP::header value NOTIFY]}]
Hi David,
The syslog facility name is notice, not notify. If you use this it should work:
log local0.notice “\[SIP::header value NOTIFY\]: [SIP::header value NOTIFY]”
Aaron
I found answer, basically NOTIFY is SIP method , which is not a part of SIP::header. Cheers
