about regular expressions
Customer will access follow uri:
http://www.test.com/server1
http://www.test.com/server2
http://www.test.com/serverN
I want redirect to relate resource base on server1/server2/…/serverN, how can I write this irules?
such as http://www.poc.com/server1 or pool pool_server1.
Hi Benjamin,
When you match up the URI “ServerN” where exactly do you want to redirect to? Do you want to direct it to a pool based on the uri then you could do the following
   set poolname [HTTP::uri]
   if { ([HTTP::host] eq "www.test.com") and ([HTTP::uri starts_with "/server" } {
      pool pool_$poolname
NOTE: This is untested code
I hope this helps
Bhattman
Hey CB,
I think you’d want to strip the leading forward slash from the URI. Also, you might want to take just the server to form the pool name:
    Check if Host is www.test.com and URI starts with /server
   if { ([HTTP::host] eq "www.test.com") and ([HTTP::uri] matches_glob {/server[0-9]*}) } {
      log local0. "[IP::client_addr]:[TCP::client_port]: Parsed [string range [HTTP::uri] 1 7] from [HTTP::uri]"
       Select the pool, taking just server from the URI
      pool pool_[string range [HTTP::uri] 1 7]
Or if you’re not on 10.x and can’t use matches_glob, you can use string match:
   if { ([HTTP::host] eq "www.test.com") and ([string match {/server[0-9]*} [HTTP::uri]]) } {
To do a redirect, you could replace the pool command with
HTTP::redirect “http ://www.example.com[HTTP::uri]”
or maybe something like
HTTP::redirect “http ://www.example.com[string range [HTTP::uri] 0 7]”
Aaron
You are right…That is what happens when you have sleep deprivation.
Bhattman
Thanks for your help! I will try it.
I try this irules, but I cannot use “string matches” in v9.x, why?
Sorry, that was a typo. It should be string match not string_match. Can you try the fixed version above?
Thanks, Aaron
