It just came to my understanding that when applying SSL profile on a virtual server, openSSL would not really be used. Well it would be used at a base level but at an upper level it’s controlled by TMOS. Am I right ? (sorry if it’s not well explained…)
So i was wondering if the traffic coming from internet and passing through the virtual server would be subject to openSSL’s known vulnerabilities? (knowing that it is not really used)
Hi
F5’s security-vulnerabilities within the documentation show OpenSSL vulnerabilities (CVE’s) affecting some of their BIG-IP products. Example below:
Sorry, I cannot anwser in depth on the SSL processing performed by the BIG-IP.
However, it looks like they are affected by certain OpenSSL vulnerabilites.
Hope this helps.
DEFAULT cipher does not use OpenSSL library and is not affected by OpenSSL vulnerabilities!
If you change profile cipher to include COMPAT keyword, BIGIP will use OpenSSL library!
