Hello,
Is there a trust level for IP intelligence?
What are the categories?
Any help is appreciate.
Hello,
Hi Samyang
IP intelligence prevent attack in level of IP, You can find categories of IP intelligence in link below,
Usually you need to stop the spam category as a lot of ISP providers change the customer public ip addresses and a spam ip address could now be attached to a legitimate customer. Change the category to logging and see if I am correct as I need to make this category in logging only not blocking mode.
If you got your answer please mark the reply that solved your issue as a solution. Thanks in advance.
