About GRE Tunnel
Does BIGIP 3600 support GRE tunnel?
I have one working in my lab via the wildcard forwarding virtual that supports all protocols
CB
I means GRE Tunnel terminated on F5 BIGIP instead of forwarding virtual.
is it possible to terminate GRE tunnel on F5 BIGIP??? Can somebody help?
I believe they support tunneling through ZebOS. There is also a way via Linux straight.
I know that F5 contains the necessary libraries to create GRE tunnel therefore you should be able to use the use “ip tunnel” and "ip link. ", but I am not sure if F5 supports that method. My suggestion is Go to Google and look up Linux Online GRE Tunneling and contact F5 to see if they support GRE Tunnels based on “ip tunnel” and “ip link”.
I hope this helps
CB
