Hello,
I have a question..
Why does the length of the dossier generated with the command line seem to be different? (much shorter)
#get_dossier -b XXXX-XXXX-XXXX-XXXX
Any help is appreciated.
Hello,
I have a question..
Does your license include add-on keys? You’ll need to specify those too when using the get_dossier command.
webUI relicensing tool automatically recognizes them
Hi
Yes,I have.
I’m just curious as to why the length of the dossier produced are different.
different how?
with and without add-on keys?
via cli or via webgui?
Hi boyneyard,
different how?
---> The length of the string is not the same
---> without
---> via Cli
Sorry, i probably asked the wrong questions.
From the start, you say you see a difference in dossier length.
Between which two types of generating a dossier?
Hi boneyard,
Thanks for your reply.
Then F5 will generate the dossier,I’m just curious as to why the length of the dossier produced are different.
ok, so always via #get_dossier -b XXXX-XXXX-XXXX-XXXX
then where is the difference? if you do this on the same BIG-IP or on different ones?
Hi boneyard,
F5 operating condition is normal.
I’m just curious as to why the length of the dossier produced are different…
Great the F5 is operating normal.
I still dont quite get what you are comparing, when is the length of the dossier different?
