about compress and cache for html or asp
I use bigip, and be testing Web acceleration.
Be spending HTML and JSP and ASP contents to a web page in order to test.
HTML of a page does Caching only, and I will compress ASP only.
I will thank if I inform an iRule technique related to setting on above content
Presumably you have a RAMCache license. You do not need an iRule to configure RAMCache to cache HTML pages. For the compression part, you can just use the COMPRESS::enable if the HTTP::path ends in \.asp.*
However, if you really want Web Acceleration, you really should consider getting the F5 Web Accelerator product.
