Hi everyone,
For last couple days I am trying to configure JavaScirpt minification for some gambling site, but no luck. I created leaf node JS, in Maching Rule I put “PATH starts with /”, and “Extension is js”. I even added “Content-Type matches includes.*”. In Acceleration rule in Assembly I marked checkbox “Enable JavaScript and CSS Minification”, but my JavaScript code is not getting minificated. Anybody knows what we are doing wrong?
This is the first time we are trying to configure AAM so any advice and help is more than welcome
Ana
I suggest enabling X-WA-Info headers (enabled in advanced application settings--choose standard or debug).
When you subsequently request your javascript through bigip, you should get a header which looks like this:
X-WA-Info: [V2.S10201.A82433.P18038.N13694.RN0.U3291613691].[OT/all.OG/includes].[P/0.2].[O/0.1].[EH1/0].[DH1/0].[C/Pk.s].[K/n]
Then you can decode that on your bigip at the shell prompt to see what policy node matched the request:
wainfodecode '[V2.S10201.A82433.P18038.N13694.RN0.U3291613691].[OT/all.OG/includes].[P/0.2].[O/0.1].[EH1/0].[DH1/0].[C/Pk.s].[K/n]'
V2: X-WA-Info Format Version
S10201: Response was served from the origin web server, because the request was for new content.
A82433: Application: /Common/intranet
P18038: Local-policy: /Common/Copy2 of Generic Policy - Complete
N13694: Request Policy Node: Includes
RN0: Response match did not supersede request match
UCI hash: c43209fb
Object type: all
Object group: includes
Request served from TMM: 0.2
Request owned by TMM: 0.1
Entity hit count (local/remote): 1/0
Document hit count (local/remote): 1/0
Document cacheable, but not seen enough to cache.
Reason: Usable content received.
Bypass: Cache score does not meet caching threshold.
Parking: Not parked.
If the node which matched is not the node you expected (where you enabled minification) you need to adjust your matching rules until the rule you expect to match does so.
If you get no X-WA-Info header at all, you may not have AM enabled at all.
Ok, I did this as you explained above. So at first I get “Reason: Object does not fall within required size limits.”, then I changed object size limits within acceleration profile and document is cached. But still no minification
Without more information than you’ve given it’s hard to guess but does OWS serve your JS with a content-type: application/javascript header?
