A customised ICMP Monitor
The default ICMP monitor only allows pinging either 1 IP or all IPs if I understand correctly.
Could someone please advise how I could setup only ONE monitor (ICMP) to ping 2 IP addresses such that the pool with this monitor applied to will be shown offline only when both IPs are not pingable.
2 separate monitors is not an option in my case.
Thanks.
Regards,
Jackie
Type External and shell script?
As Paja mentioned you could use an external monitor to do this. You can check the monitoring codeshare for examples (Click here).
Aaron
