Quick question which should be easy enough to answer…Is it possible to go straight from 9.4.7 to 10.2.4?
Cheers
Lee
Cheers
Lee
Hi Lee,
Yes you can. See the 10.2.4 release notes section for upgrading from previous versions for details:
Aaron
Doh! Can’t believe I didn’t read that
Thanks Aaron
