Trying to start with just getting the device versions, similar to this example - DevCentral - An F5 Technical Community
I can get the list of devices just fine from the EM. I can get the context_id from the EM When I set the context to the IP address of the device, I get back “OK”
But, when I try to send the get_version command
$resp = $soap->uri("urn:iControl:System/SystemInfo")->get_version();
What I get back is:
502 Proxy Error at f5-em.pl line 98.
Line 98 being the line in the perl script that is shown above sending the get_version.
I know I have connectivity to the EM, I know I can set context, and I know I can do ‘get_version’ if I go direct to the LTM.
Is there any way to tell exactly what is causing the proxy error?
