Problem: If the page returns a 200 but there is a missing image, the redirect will take place. I was under the impression that the whole page has to returned 404 before to set the “HTTP::status” to true. Is that correct or am I missing something?
A page is merely a collection of objects for which HTTP GET requests must be made. If for instance a page had 12 images, a 404 for any of them could trigger the rule. Also, HTTP::host shouldn’t be used in HTTP_RESPONSE since there’s no host header. You’ll want to set a variable from HTTP_REQUEST and check the variable from HTTP_RESPONSE.
Something like this would work:
set hostvar [HTTP::host] } }
when HTTP_RESPONSE {
if { [HTTP::status] eq "404" } {
if a 404 is returned, send a 301 redirect for our custom 404 page
HTTP::respond 301 Location "http://$hostvar/portal/site/erp/404/" } }
I understand, but what if condition would be used if you’re just interested if the page it’s self is rendered? Meaning we can ignore the x images that are missing as long as the page is found and renders to the browser.
I didn’t think the browser would follow a redirect if the 30x response came for an element within the page. Can you use a browser plugin like HttpFox for Firefox or Fidder to see exactly what’s triggering the change of the page?
