Hello Everyone,
I am planning to build a webpage where APP Users can login and able to see their pool data and make changes like disable enable force offline and stats of that pool.
I wanted to know how to achieve this and any one having any example templets on this? Like creating a webpage or what code of script we can use for API calls? (Python, Perl, or any easy one) and few heads-up while creating one.
Appreciate the assistance.
Maybe this will help:
BIG-IP Report | DevCentral
Cheers,
Kees
Okay, this seems to be a Status page. Actually Iam looking for a DashBoard for the Pool Maintenance.
Here is some information about the REST API you’d probably want to use:
For the architecture and framework of the web app, there are of course lots of options! You could call the F5 directly from the browser using asynchronous calls, or you could proxy them on a backend app server.
