Hi
I have some question about software that support with BIG-IP 3600
from this SOL : 404 Page not found | BIG-IP Documentation
you can see 10.2.4 is supported
but from this metric : big-ip-product-matrix.pdf
you can see 3600 is supported until 9.4.6
This is currently active module.
active module : ADD 100 MBPS COMPRESSION| ADD 100 MBPS COMPRESSION
active module : ADD 100 MBPS COMPRESSION| 100 MBPS COMPRESSION
active module : Local Traffic Manager, 3600 Local Traffic Manager Module|ADD IPV6 GATEWAY|ADD RATE SHAPING|ADD RAMCACHE|50 MBPS COMPRESSION|SSL 500 TPS Per Core|ADD SSL CMP|ADD ANTI-VIRUS CHECKS|ADD BASE ENDPOINT SECURITY CHECKS|ADD FIREWALL CHECKS|ADD MACHINE CERTIFICATE CHECKS|ADD NETWORK ACCESS|ADD PROTECTED WORKSPACE|ADD SECURE VIRTUAL KEYBOARD|ADD WEB APP
Can I upgrade to v. 10.2.x or 11.x with this platform?
Thank you
