Hi.
Just wondering if it is possible to have 3 GTMs that only share selected information with each other about a particular zones. Let me give you an example.
I have 3 GTMs, one at Data Center A, Data Center B, and Data Centre C respectively.
In Data Center A and B, there are applications x.acme.tld and y.acme.tld
In Data Center B and C, there are applications y.acme.tld and z.acme.tld
w.acme.tld is available in Data Centers A, B, and C.
Is it possible to share configuration of x.acme.tld and y.acme.tld between the GTM at Data Center A and B only?
Is it possible to share configuration of y.acme.tld and z.acme.tld between the GTM at Data Center B and C only?
Is it possible to share w.acme.tld to the GTM in all 3 data centres?
Thanks, -mike.
