2-way SSL
Hello Experts,
I have a question here:
For the 2-way SSL, we already offloaded the certs on f5 VIP and user is providing the other certificate from their side. But, it didn’t work until the minute we provided them the private key. Since this is not a safe practice, is there a way we can install the user-side certificate on the LB VIP along with the root cert?
The another problem is, since there are many customers, we won’t be able to install that many certs so please help us with the solution.
(My apologies for the poor technical wording - better clarification is appreciated as well)
Regards,
R
You don’t need to install the client-side certificate on the BIG-IP, you only have to specify the trusted Certificate Authority that signed the user’s certificate - this is a great place to start reading to understand how to do that: SSL Profiles Part 8: Client Authentication - F5 Technical Articles - DevCentral - An F5 Technical Community
Particularly the part under “BIG-IP Configuration”
