Greetings! We have clients that use 2-way SSL on some of their pages/paths. One of the clients has recently ran a security scan and asked us we remove SSL renegotiation from their profile. Disabling renegotiation has also disabled 2-way SSL we had for them on the profile.
Is there a way to have renegotiation disabled and the 2-way SSL working at the same time?
The 2-way SSL is setup on LTM.
Thanks for your help!
On the SSL server profile, change Secure Renegotiation to ‘require’ or ‘require strict’ in order to disable insecure negotiation. Keep in mind that if the back end server isn’t patched for this, it could break SSL connections through the LTM.
Thanks, Cory! I tried both ‘require’ and ‘require strict’ and it didn’t work. The client cert is not being asked for. What did you mean by ‘if the back end server isn’t patched for this’? Currently, the servers have secure bindings for the site configured with our wildcard cert.
The server should be patched for the SSL/TLS renegotiation vulnerability listed here: RFC 5746 - Transport Layer Security (TLS) Renegotiation Indication Extension If you need client certificate based authentication, I recommend you use proxy SSL. You enable it within both the client and SSL profiles. 404 Page not found | BIG-IP Documentation
Proxy SSL is not an acceptable solution for us as we terminate SSL connections at the F5. I believe our web servers are fully patched.
We also terminate SSL on our LTMs and use proxy SSL. You can do both. The purpose of it is to maintain client certificate based authentication while at the same time allowing layer 7 inspection on the LTM.
Hi Cory, is it a big change to switch to proxy SSL on the F5s? Does it have to be done for all virtual servers or can it be implemented for individual VS’s? We have about 500 sites hosted on the F5s.
It can be implemented per client and server SSL profile simply by checking a box. But it will need to be checked on all profiles applied to the virtual server that you want to enable it on. Note that in order for it to work you must load the server certificate and key and apply to both the client and server profiles.
It looks like we don’t have the Proxy SSL check box in the client profile section. See the screenshot. Does it mean the version we have doesn’t support it? We have 10.2.3
Yes, proxy SSL was introduced in v11. Unsure exactly which version right off hand but we have it in 11.2
OK. Does it mean we don’t have any solution for to have the renegotiation disabled and client SSL authentication at the same time unless we upgrade the F5s?
Unfortunately you’ll have to upgrade to get the functionality. Though the server could be patched to eliminate the vulnerability and you wouldn’t need to upgrade. I’m no server guy so I don’t know what kind of effort that would entail.
