I was reading articles and post related to implementing 2-factor authentication for access to applications served by BIG-IPs. Seems to be plenty options especially when using APM.
My question is about a way to use 2-factor for management access - I did not found any resources. Is that at all possible? No way to use iRules (or I am not aware of any), no build in mechanisms… so is there any option here?
Maybe at least there is a way to force certificate based client authentication?
Piotr
not sure if it is a good idea but you can access configuration utilities via virtual server i.e. irule can be used.
sol13981: Restricting access to the Configuration utility using client certificates (11.x)
Hi, Well, I should be less lazy and use search :-), thanks for help. What do you mean by using VS for accessing GUI? Create VS that is pointing to SelfIP as pool member (on port 443)? That could be solution for GUI, but I guess there is none like that for SSH? Piotr
