After moving to 13.1.0.1 Firefox doesn’t display all pages. Example - Device Management, Overview and Traffic Groups only display blank pages. Others seen this, found a work around?
no issues for me either, did you try clear cache?
Well I don’t have the issue now. There were 3 of us that saw the exact same thing when the UI came up after completing the move to 13.1. Today no one has the problem.
It’s possible that the GUI was not quite all-the-way up when you logged in. I have seen strangeness from time-to-time when accessing the GUI immediately when it becomes available. Glad it’s working as designed now!
I had the same problem a couple of days ago when I upgraded one of our clusters to 13.1.0.2. At some process during that upgrade that same page was empty for me as well, but after everything was up and cluster was in sync everything was normal again. Didn’t spend to much time investigating it.
I have the same issue. Upgraded 2 separate clusters to 13.1
Today one of them is blank, the other works fine from the same browser on the same machine
