In 11.1, the following methods were removed:
Management.DeviceGroup.get_last_sync_time
Management.DeviceGroup.get_member_states
Management.DeviceGroup.get_sync_state
The remaining methods available to the user for tracking the status of a device’s configuration are:
System.ConfigSync.get_configuration_list
Get_configuration_list will tell the user the modification time of config.ucs, but synchronization IS itself a modification and thus n identical devices with the same, synchronized configuration will show different modification times.
The removal of the three methods from DeviceGroup makes it impossible for the user to determine whether the nodes in the DeviceGroup are ACTUALLY IN SYNC, short of downloading the config of each device and doing a binary comparison. Which is not a reasonable solution since F5 itself DOES KNOW WHETHER ITS DEVICE GROUP IS SYNCHRONIZED, because it can show it in the web ui.
I’ve combed through the API for alternative solutions but so far I haven’t been able to find anything. In 11.1, an icontrol user has no ability to ask f5 if f5 is in sync.
