Hello all,
I am working on LTM 11.4 soon to upgrade to 12.1 or 13. I have 100’s of redirect policies. They test out as 302 redirects. How do I get them to redirect as 301 permanent redirects.
Hello all,
If you move to v14, you have the option to set the code in the redirect rule.
In earlier versions, I used to set a tcl variable on policy rule and read then in iRule script.
I don’t have a v11.4 screenshot, but it’s close to this:
The iRule content:
if { [info exists redirect301] } {
HTTP::respond 301 -version auto noserver Location $redirect301 Connection close
unset redirect301
If you decide to change it before move to v14, to replace hundred of rules, you can list policies and run a script or manually edit then to merge it on command line:
e.g.
tmsh list ltm policy my_policy |awk '{ sub(/http-reply$/,"tcl") sub(/redirect$/,"set-variable name redirect301") sub(/location(.*)$/,"expression " $2) }1'
Original content / before to be edited:
ltm policy my_policy {
controls { forwarding }
requires { http }
rules {
rule1 {
actions {
0 {
http-reply
redirect
location https://www.mydomain.net[HTTP::uri]
ordinal 1
strategy first-match
After run command / edit:
requires { http }
rules {
rule1 {
actions {
0 {
tcl
expression https://www.mydomain.net[HTTP::uri]
ordinal 1
You must check if all rules are right, OK? ![]()
Then, you can save it on file (e.g. myfile.conf) to merge on command line or read from terminal.
See:
Make sure it’s all OK with “verify” statement:
e.g.
# tmsh load sys config merge file /var/tmp/myfile.conf verify
When all it’s OK, merge it:
Please, run a backup before make changes.
I hope it helps.
You, my fine man, are a godsend. Thank you so much Claudio!
wow, nice to hear it. When confirm it works, please mark this question as solved.
Cheers
