Fellow pycontrol-freaks ![]()
I’ve been on a coding marathon for 2 days and have had a fantastic time diving into pycontrol !!
I’m trying to use it to dynamically add a maintenance irule and then remove it again based on a ruby script that’s out on devcentral.
However, I’m running into a wall finally and it smells like a bug or massively misleading API error to me.
I know that icontrol is stricter than the gui and won’t let me add 2 irules with the same priority except I can prove to you that it does anyway whereas I cannot add a 3rd iRule
if 2 exist already no matter what the priorities are.
Case in point. I have a test vs with no irules. I can use my pycontrol script to add a redirect rule no problem.
SCENARIO 1 (works when it shouldn’t) :
[stucky@vito pycontrol]$ ./maintenance.py blablabla
The iRule ‘api_maintenance’ already existed but got refreshed.
Successfully added iRule ‘api_maintenance’ to virtual server ‘/Common/test’
The irule is set to priority 1 :
[root@stglbltm01:Active:Standalone] config tmsh show ltm rule api_maintenance
Ltm::Rule Event: api_maintenance:HTTP_REQUEST
Priority 1
Executions
Now as per docs I should not be able do this again if another rule with pri 1 already exists. To test let’s remove this rule again and manually add the test rule with pri 1.
[root@stglbltm01:Active:Standalone] config tmsh list ltm virtual test
ltm virtual test {
destination ip:http
ip-protocol tcp
mask 255.255.255.255
profiles {
http { }
tcp { }
rules {
test_hipri
[root@stglbltm01:Active:Standalone] config tmsh show ltm rule test_hipri
Ltm::Rule Event: test_hipri:HTTP_REQUEST
Priority 1
Executions
Ok now let’s try to use pycontrol to add the maintenance rule again:
Let’s confirm we have both rules associated with the vs:
ltm virtual test {
destination ip:http
ip-protocol tcp
profiles {
http { }
tcp { }
rules {
test_hipri
api_maintenance
Now I don’t mind if something works that shouldn’t as much as I do when something doesn’t work that should !
SCENARIO 2 (Doesn’t work when it really should !!)
Let’s add 2 irules to this vs both with DIFFERENT priorities (other than 1 for sure !):
ltm virtual test {
destination ip:http
ip-protocol tcp
profiles {
http { }
tcp { }
rules {
log_persistence_cookie
filter_http_methods
We have pri 800 and pri 10.
[root@stglbltm01:Active:Standalone] config tmsh show ltm rule log_persistence_cookie
Ltm::Rule Event: log_persistence_cookie:HTTP_REQUEST
Priority 800
Executions
[root@stglbltm01:Active:Standalone] config tmsh show ltm rule filter_http_methods
Ltm::Rule Event: filter_http_methods:HTTP_REQUEST
Priority 10
Executions
According to the docs I should have no problem adding a 3rd irule with priority 1 here via pycontrol so let’s try :
No handlers could be found for logger “suds.client”
Server raised fault: 'Exception caught in LocalLB:
iControl:LocalLB/VirtualServer::add_rule()
Exception: Common::OperationFailed
primary_error_code : 17237537 (0x01070621)
secondary_error_code : 0
error_string : 01070621:3: Rule priorities for virtual server (/Common/test) must be unique.’
This totally hoses me cause I cannot finish my maintenance script testing now. It’s all moot if I can’t get this rule added/removed on the fly.
Please tell me I’m doing something wrong !
Keep up the great forum !
thx
