Better together - F5 Container Ingress Services and NGINX Plus Ingress Controller Integration
Introduction
The F5 Container Ingress Services (CIS) can be integrated with the NGINX Plus Ingress Controllers (NIC) within a Kubernetes (k8s) environment.
The benefits are getting the best of both worlds, with the BIG-IP providing comprehensive L4 ~ L7 security services, while leveraging NGINX Plus as the de facto standard for micro services solution.
This architecture is depicted below.
The integration is made fluid via the CIS, a k8s pod that listens to events in the cluster and dynamically populates the BIG-IP pool pointing to the NIC's as they scale.
There are a few components need to be stitched together to support this integration, each of which is discussed in detail over the proceeding sections.
Follow this (https://docs.nginx.com/nginx-ingress-controller/installation/building-ingress-controller-image/) to build the NIC image.
The NIC can be deployed using the Manifests either as a Daemon-Set or a Service. See this ( https://docs.nginx.com/nginx-ingress-controller/installation/installation-with-manifests/ ).
A sample Deployment file deploying NIC as a Service is shown below,
apiVersion: apps/v1 kind: Deployment metadata: name: nginx-ingress namespace: nginx-ingress spec: replicas: 3 selector: matchLabels: app: nginx-ingress template: metadata: labels: app: nginx-ingress #annotations: #prometheus.io/scrape: "true" #prometheus.io/port: "9113" spec: serviceAccountName: nginx-ingress imagePullSecrets: - name: abgmbh.azurecr.io containers: - image: abgmbh.azurecr.io/nginx-plus-ingress:edge name: nginx-plus-ingress ports: - name: http containerPort: 80 - name: https containerPort: 443 #- name: prometheus #containerPort: 9113 securityContext: allowPrivilegeEscalation: true runAsUser: 101 #nginx capabilities: drop: - ALL add: - NET_BIND_SERVICE env: - name: POD_NAMESPACE valueFrom: fieldRef: fieldPath: metadata.namespace - name: POD_NAME valueFrom: fieldRef: fieldPath: metadata.name args: - -nginx-plus - -nginx-configmaps=$(POD_NAMESPACE)/nginx-config - -default-server-tls-secret=$(POD_NAMESPACE)/default-server-secret - -ingress-class=sock-shop #- -v=3 # Enables extensive logging. Useful for troubleshooting. #- -report-ingress-status #- -external-service=nginx-ingress #- -enable-leader-election #- -enable-prometheus-metrics
Notice the ‘- -ingress-class=sock-shop’ argument, it means that the NIC will only work with an Ingress that is annotated with ‘sock-shop’. The absence of this annotation makes NIC the default for all Ingress created.
Below shows the counterpart Ingress with the ‘sock-shop’ annotation.
apiVersion: extensions/v1beta1 kind: Ingress metadata: name: sock-shop-ingress annotations: kubernetes.io/ingress.class: "sock-shop" spec: tls: - hosts: - socks.ab.gmbh secretName: wildcard.ab.gmbh rules: - host: socks.ab.gmbh http: paths: - path: / backend: serviceName: front-end servicePort: 80
This Ingress says if hostname is socks.ab.gmbh and path is ‘/’, send traffic to a service named ‘front-end’, which is part of the socks application itself.
The above concludes Ingress configuration with the NIC.
The next step is to leverage the CIS to dynamically populate the BIG-IP pool with the NIC addresses.
Follow this ( https://clouddocs.f5.com/containers/v2/kubernetes/kctlr-app-install.html ) to deploy the CIS.
A sample Deployment file is shown below,
kind: Deployment
metadata:
namespace: kube-system
spec:
# DO NOT INCREASE REPLICA COUNT
replicas: 1
template:
metadata:
labels:
app: k8s-bigip-ctlr
spec:
# Name of the Service Account bound to a Cluster Role with the required
# permissions
serviceAccountName: bigip-ctlr
containers:
- name: k8s-bigip-ctlr
image: "f5networks/k8s-bigip-ctlr"
env:
- name: BIGIP_USERNAME
valueFrom:
secretKeyRef:
# Replace with the name of the Secret containing your login
# credentials
key: username
- name: BIGIP_PASSWORD
valueFrom:
secretKeyRef:
# credentials
key: password
command: ["/app/bin/k8s-bigip-ctlr"]
args: [
# See the k8s-bigip-ctlr documentation for information about
# all config options
# https://clouddocs.f5.com/products/connectors/k8s-bigip-ctlr/latest
"--bigip-username=$(BIGIP_USERNAME)",
"--bigip-password=$(BIGIP_PASSWORD)",
"--bigip-url=https://x.x.x.x:8443",
"--bigip-partition=k8s",
"--pool-member-type=cluster",
"--agent=as3",
"--manage-ingress=false",
"--insecure=true",
"--as3-validation=true",
"--node-poll-interval=30",
"--verify-interval=30",
"--log-level=INFO"
imagePullSecrets:
# Secret that gives access to a private docker registry
- name: f5-docker-images
# Secret containing the BIG-IP system login credentials
- name: bigip-login
Notice the following arguments below. They tell the CIS to consume AS3 declaration to configure the BIG-IP. According to PM, CCCL (Common Controller Core Library) – used to orchestrate F5 BIG-IP, is getting removed this sprint for the CIS 2.0 release.
'--manage-ingress=false' means CIS is not doing anything for Ingress resources defined within the k8s, this is because that CIS is not the Ingress Controller, NGINX Plus is, as far as k8s is concerned.
The CIS will create a partition named k8s_AS3 on the BIG-IP, this is used to hold L4~7 configuration relating to the AS3 declaration.
The best practice is also to manually create a partition named 'k8s' (in our example), where networking info will be stored (e.g., ARP, FDB).
"--agent=as3",
"--insecure=true",
To apply AS3, the declaration is embedded within a ConfigMap applied to the CIS pod.
kind: ConfigMap
apiVersion: v1
metadata:
labels:
f5type: virtual-server
as3: "true"
data:
template: |
"class": "AS3",
"action": "deploy",
"persist": true,
"declaration": {
"class": "ADC",
"id":"1847a369-5a25-4d1b-8cad-5740988d4423",
"schemaVersion": "3.16.0",
"Nginx_IC": {
"class": "Tenant",
"Nginx_IC_vs": {
"class": "Application",
"template": "https",
"serviceMain": {
"class": "Service_HTTPS",
"virtualAddresses": [
"10.1.0.14"
"virtualPort": 443,
"redirect80": false,
"serverTLS": {
"bigip": "/Common/clientssl"
"clientTLS": {
"bigip": "/Common/serverssl"
"pool": "Nginx_IC_pool"
"Nginx_IC_pool": {
"class": "Pool",
"monitors": [
"https"
"members": [
"servicePort": 443,
"shareNodes": true,
"serverAddresses": []
They are telling the BIG-IP to create a tenant called ‘Nginx_IC’, a virtual named ‘Nginx_IC_vs’ and a pool named ‘Nginx_IC_pool’. The CIS will update the serverAddresses with the NIC addresses dynamically.
Now, create a Service to expose the NIC’s.
apiVersion: v1 kind: Service metadata: name: nginx-ingress namespace: nginx-ingress labels: cis.f5.com/as3-tenant: Nginx_IC cis.f5.com/as3-app: Nginx_IC_vs cis.f5.com/as3-pool: Nginx_IC_pool spec: type: ClusterIP ports: - port: 443 targetPort: 443 protocol: TCP name: https selector: app: nginx-ingress
Notice the labels, they match with the AS3 declaration and this allows the CIS to populate the NIC’s addresses to the correct pool. Also notice the kind of the manifest ‘Service’, this means only a Service is created, not an Ingress, as far as k8s is concerned.
On the BIG-IP, the following should be created.
The end product is below.
Please note that this article is focused solely on control plane, that is, how to get the CIS to populate the BIG-IP with NIC's addresses.
The specific mechanisms to deliver packets from the BIG-IP to the NIC's on the data plane is not discussed, as it is decoupled from control plane. For data plane specifics, please take a look here ( https://clouddocs.f5.com/containers/v2/ ).
Hope this article helps to lift the veil on some integration mysteries.
27 Comments
Thanks just I was studying for my F5 cloud expert cert and I was curious if I was missing something.
- Chris_ZhangRet. Employee
Good eye, Nikoolayy1! Yes, the picture should show 3
Why the pool is with 5 Nginx conrollers ? Shouldn't it be with 3 "replicas: 3"?
One CIS can only speak to one BIG-IP. But you can have multiple CIS's with each talking to its associating BIG-IP.
- kunalpuriii
Altocumulus
yes not 20, but yes multiple F5 , 8 HA pair to be specific. Yes same configuration
. Just to clarify, are you looking at injecting the same configs (e.g., VIP, pool) to all 20 F5's?
- kunalpuriii
Altocumulus
Also is it any limitation to specify no. of F5 in --bigip-url=https://x.x.x.x:8443
Can we update multiple F5(20) from the same CIS by specifying different bigip url in the same CIS POD?
- kunalpuriii
Altocumulus
thanks for your response, I actually tested it in the past and have tested it again. If we dont have f5-appsvcs installed in F5, F5 does not get AS3 update. Thus new pool member are not updated.
- Eric_Chen
Employee
AS3 does need to be installed on each device. The BIG-IP Controller for Kubernetes talks directly to the BIG-IP device.
- kunalpuriii
Altocumulus
Thanks for all your help sofar.
I have question regarding AS3 extension, currently we have test this integration by installing AS3 extension under iApps > Package Management LX. in F5( Is this a pre-requisite or a definite requirement)
We have 10+ opco's and vCMP is deployed for all of the, do I need to install AS3 extension in all the vCMP's to have AS3 support, Is there any centralized designed may be using BIG IQ? or any other centralized server?
Kunal Puri
