SSL forward proxy with web acceleration iApp template
Problem this snippet solves:
This iApp template configures a wildcard virtual server and associated objects required for accelerating outbound traffic to SaaS applications. The BIG-IP SSL forward proxy feature is used to decrypt client-side traffic and re-encrypt the traffic before forwarding to the destination, with Web Accelerator storing a local copy of application resources as according to a pre-defined custom acceleration policy (see below).
v0.1.0
Version 0.1.0 of this iApp template contains improvements to the original template including inline help and additional acceleration and optimization options such as OneConnect and HTTP compression.
NOTE: This version of the iApp template works on BIG-IP versions 11.3 and later. You must have licensed and provisioned both LTM and AAM/WAM modules.
v1.0.0rc1
Version 1.0.0 of this iApp includes explicit forward proxy options, as well as support for LTM policy and additional inline help.
NOTE: This version of the iApp template works on BIG-IP versions 11.5 and later. You must have licensed and provisioned both LTM and AAM/WAM modules.
v1.1.0rc2
Fixed an issue with the associated cli script that could prevent users from importing iApp templates.
For instructions on using this iApp template, or manual configuration guidance, see http://www.f5.com/pdf/deployment-guides/f5-saas-dg.pdf
Code :
46495
