python f5-sdk - Reverse Lookup (Node -> Pool)
Problem this snippet solves:
This python bigsuds script prints the list of pools using a specific node.
How to use this snippet:
rlookup-node.py <hostname> <username> <nodename>
Script will prompt for password.
This will only search the Common partition.
Code :
#!/usr/bin/env python
__author__ = 'buzzsurfr'
__version__ = '0.2'
# Standard Library
import sys
import re
# Related Third-Party
import getpass
# Local Application/Library Specific
from f5.bigip import ManagementRoot
if len(sys.argv) < 4:
print "\n\n\tUsage: %s host user node" % sys.argv[0]
sys.exit()
# Get login password from CLI
userpass = getpass.getpass()
# Connect to BIG-IP
mgmt = ManagementRoot(sys.argv[1], sys.argv[2], userpass)
# Get list of pools and pool members
pools = mgmt.tm.ltm.pools.get_collection()
# Node to search for
node = sys.argv[3]
if len(node) < 8 or node[:8] != '/Common/':
node = '/Common/'+node
print "Pools using Node "+node
# Iterate through pool member list (has a list of members per pool referenced) looking for node
for pool in pools:
member_nodes = [member.fullPath.split(':')[0] for member in pool.members_s.get_collection()]
if node in member_nodes:
print "\t"+pool.nameTested this on version:
11.5Updated Jun 05, 2023
Version 2.0Theo_12742
Cirrus
Joined November 19, 2012
