pycontrol v2 - Class Management
Problem this snippet solves:
This pyControl v2 script will help manage classes
How to use this snippet:
Note only does the 3 types of classes (string, address and value).
Usage:
.\Update-Class-Value.py --bigip --username <--create|--delete|--list> --class_name --classtype --add -
-delete
ex.
If creating/deleting a class,specify class name and type:
.\Update-Class-Value.py --bigip 192.168.1.245 -username admin --create --classname my_address_class --classtype address
If adding/removing entries to existing class ( will attempt to guess what type ):
For an Address class, use comma seperated string like:
.\Update-Class-Value.py --bigip 192.168.1.245 --username admin --classname my_address_class --addkey "10.10.0.0/255.255.0.0,10.20.0.0/255.255.0.0"
or with values:
.\Update-Class-Value.py --bigip 192.168.1.245 --username admin --classname my_address_class --addkey "10.10.0.0/255.255.0.0,10.20.0.0/255.255.0.0" --addvalu
e "my_pool_1,my_pool_2"
For an value class, use comma seperated string like:
.\Update-Class-Value.py --bigip 192.168.1.245 --username admin --classname my_value_class --addkey "10000,20000" --addvalue "my_pool_1,my_pool_2"
or with values:
For an string class, use comma seperated string like:
.\Update-Class-Value.py --bigip 192.168.1.245 --username admin --classname my_string_class --addkey "app1.example.com,app2.example.com"
or with values:
.\Update-Class-Value.py --bigip 192.168.1.245 --username admin --classname my_string_class --addkey "app1.example.com,app2.example.com" --addvalue "my_pool_
1,my_pool_2"
DISCLAIMER: Obviously CSV is a really bad assumption for string class but feel free to modify yourself.
Script
Manage-Class.py
Code :
#!/bin/env python
The contents of this file are subject to the "END USER LICENSE AGREEMENT FOR F5
Software Development Kit for iControl"; you may not use this file except in
compliance with the License. The License is included in the iControl
Software Development Kit.
Software distributed under the License is distributed on an "AS IS"
basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See
the License for the specific language governing rights and limitations
under the License.
The Original Code is iControl Code and related documentation
distributed by F5.
The Initial Developer of the Original Code is F5 Networks,
Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2004 F5 Networks,
Inc. All Rights Reserved. iControl (TM) is a registered trademark of F5 Networks, Inc.
Alternatively, the contents of this file may be used under the terms
of the GNU General Public License (the "GPL"), in which case the
provisions of GPL are applicable instead of those above. If you wish
to allow use of your version of this file only under the terms of the
GPL and not to allow others to use your version of this file under the
License, indicate your decision by deleting the provisions above and
replace them with the notice and other provisions required by the GPL.
If you do not delete the provisions above, a recipient may use your
version of this file under either the License or the GPL.
################## BEGIN DEFINITIONS #########################
def usage():
print "Usage:"
print "%s --bigip -username <--create|--delete|--list> --class_name --classtype --add --delete " % sys.argv[0]
print "\tex."
print "\tIf creating/deleting a class,specify class name and type:"
print "\t\t%s --bigip 192.168.1.245 -username admin --create --classname my_address_class --classtype address" % sys.argv[0]
print "\tIf adding/removing entries to existing class ( will attempt to guess what type ):"
print "\t For an Address class, use comma seperated string like:"
print "\t\t%s --bigip 192.168.1.245 -username admin --classname my_address_class --addkey \"10.10.0.0/255.255.0.0,10.20.0.0/255.255.0.0\"" % sys.argv[0]
print "\t\tor with values:"
print "\t\t%s --bigip 192.168.1.245 -username admin --classname my_address_class --addkey \"10.10.0.0/255.255.0.0,10.20.0.0/255.255.0.0\" --addvalue \"my_pool_1,my_pool_2\"" % sys.argv[0]
print "\t For an value class, use comma seperated string like:"
print "\t\t%s --bigip 192.168.1.245 -username admin --classname my_value_class --addkey \"10000,20000\" --addvalue \"my_pool_1,my_pool_2\"" % sys.argv[0]
print "\t\t%s --bigip 192.168.1.245 -username admin --classname my_value_class --addkey \"10000,20000\"" % sys.argv[0]
print "\t For an string class, use comma seperated string like:"
print "\t\t%s --bigip 192.168.1.245 -username admin --classname my_string_class --addkey \"app1.example.com,app2.example.com\"" % sys.argv[0]
print "\t\t%s --bigip 192.168.1.245 -username admin --classname my_string_class --addkey \"app1.example.com,app2.example.com\" --addvalue \"my_pool_1,my_pool_2\"" % sys.argv[0]
print "DISCLAIMER: Obviously CSV is a really bad assumption for string class but feel free to modify yourself."
def create_class(obj, class_name, class_type):
try:
print "Trying To Create Class" + class_name + " of class type " + class_type
if class_type == "address":
class_obj = obj.LocalLB.Class.typefactory.create('LocalLB.Class.AddressClass')
class_obj.name = class_name
class_obj.members = []
obj.LocalLB.Class.create_address_class( classes = [ class_obj ])
if class_type == "value":
class_obj = obj.LocalLB.Class.typefactory.create('LocalLB.Class.ValueClass')
obj.LocalLB.Class.create_value_class( classes = [ class_obj ])
if class_type == "string":
class_obj = obj.LocalLB.Class.typefactory.create('LocalLB.Class.StringClass')
obj.LocalLB.Class.create_string_class( classes = [ class_obj ])
except:
print "Can't create Class: %s" % class_name
traceback.print_exc(file=sys.stdout)
def delete_class(obj, class_name):
try:
obj.LocalLB.Class.delete_class( classes = [ class_name ])
except:
def add_key(obj, class_name, class_keys):
#only add key if doesn't exist
try:
#Get Type of Class first
class_type_seq = obj.LocalLB.Class.get_class_type( class_names = [ class_name ])
class_type = class_type_seq[0]
#Container for existing Classes/Keys
existing_classes = []
existing_keys = []
if class_type == "CLASS_TYPE_ADDRESS":
#Get Existing Entries
existing_classes = obj.LocalLB.Class.get_address_class( class_names = [ class_name ] )
# Assuming only retrieving one class
for key in existing_classes[0].members:
#Store keys in same string format as input. ex. "10.20.0.0/255.255.0.0"
existing_keys.append( str(key.address) + "/" + str(key.netmask) )
class_members_seq = obj.LocalLB.Class.typefactory.create('LocalLB.Class.AddressClassSequence')
class_members_seq.item = []
address_class_obj = obj.LocalLB.Class.typefactory.create('LocalLB.Class.AddressClass')
address_class_obj.name = class_name
address_class_obj.members = []
# Change seperator to whatever works for you
key_seq = class_keys.split(",")
for key in key_seq:
(address,netmask) = key.split("/")
address_entry_obj = obj.LocalLB.Class.typefactory.create('LocalLB.Class.AddressEntry')
address_entry_obj.address = address
address_entry_obj.netmask = netmask
if key not in existing_keys:
address_class_obj.members.append(address_entry_obj)
class_members_seq.item.append(address_class_obj)
if address_class_obj.members:
obj.LocalLB.Class.add_address_class_member( class_members = class_members_seq )
if class_type == "CLASS_TYPE_STRING":
existing_classes = obj.LocalLB.Class.get_string_class( class_names = [ class_name ] )
existing_keys.append(key)
class_members_seq = obj.LocalLB.Class.typefactory.create('LocalLB.Class.StringClassSequence')
string_class_obj = obj.LocalLB.Class.typefactory.create('LocalLB.Class.StringClass')
string_class_obj.name = class_name
string_class_obj.members = []
for key in key_seq:
string_class_obj.members.append(key)
class_members_seq.item.append(string_class_obj)
if string_class_obj.members:
obj.LocalLB.Class.add_string_class_member( class_members = class_members_seq)
if class_type == "CLASS_TYPE_VALUE":
existing_classes = obj.LocalLB.Class.get_value_class( class_names = [ class_name ] )
existing_keys.append( str(key) )
class_members_seq = obj.LocalLB.Class.typefactory.create('LocalLB.Class.ValueClassSequence')
value_class_obj = obj.LocalLB.Class.typefactory.create('LocalLB.Class.ValueClass')
value_class_obj.name = class_name
value_class_obj.members = []
for key in key_seq:
print "adding Key : %s" % key
value_class_obj.members.append(key)
class_members_seq.item.append(value_class_obj)
if value_class_obj.members:
obj.LocalLB.Class.add_value_class_member( class_members = class_members_seq)
return class_members_seq
except:
print "Failed to add keys to class: %s" % class_name
def remove_key(obj, class_name, class_keys):
try:
for entry in key_seq:
(address,netmask) = entry.split("/")
obj.LocalLB.Class.delete_address_class_member( class_members = class_members_seq)
for key in key_seq:
obj.LocalLB.Class.delete_string_class_member( class_members = class_members_seq)
for key in key_seq:
obj.LocalLB.Class.delete_value_class_member( class_members = class_members_seq)
except:
print "Failed to delete keys in class: %s" % class_name
def get_list(obj):
try:
address_class_list = obj.LocalLB.Class.get_address_class_list()
string_class_list = obj.LocalLB.Class.get_string_class_list()
value_class_list = obj.LocalLB.Class.get_value_class_list()
print "Address Classes:"
for my_class in address_class_list:
print "\t" + my_class
print "String Classes:"
for my_class in string_class_list:
print "Value Classes:"
for my_class in value_class_list:
except:
print "Failed to get list of classes"
def get_members(obj, class_name):
try:
classes_output = obj.LocalLB.Class.get_address_class( class_names = [ class_name ] )
class_values = obj.LocalLB.Class.get_address_class_member_data_value ( class_members = classes_output )
for i in range(len(classes_output)):
print "Class Name: \"" + classes_output[i].name + "\""
print "Class Members: "
print "%-30s" % "key" + "%s" % "value"
print "%-30s" % "-----" + "%s" % "-----"
members = classes_output[i].members
for j in range(len(members)):
key_string = str(members[j].address) + "/" + str(members[j].netmask)
print "%-30s" % key_string + "%s" % class_values[i][j]
classes_output = obj.LocalLB.Class.get_string_class( class_names = [ class_name ] )
class_values = obj.LocalLB.Class.get_string_class_member_data_value ( class_members = classes_output )
print "%-30s" % members[j] + "%s" % class_values[i][j]
classes_output = obj.LocalLB.Class.get_value_class( class_names = [ class_name ] )
class_values = obj.LocalLB.Class.get_value_class_member_data_value ( class_members = classes_output )
except:
print "Failed to list class members for class: %s" % class_name
def add_value( obj, class_name, class_keys, class_values ):
try:
values_input_seq = class_values.split(",")
values_seq_seq = obj.LocalLB.Class.typefactory.create('Common.StringSequenceSequence')
values_seq_seq.item = []
values_seq = obj.LocalLB.Class.typefactory.create('Common.StringSequence')
values_seq.item = []
for value in values_input_seq:
values_seq.item.append( value )
values_seq_seq.item.append( values_seq )
for key in key_seq:
obj.LocalLB.Class.set_address_class_member_data_value (
class_members = class_members_seq,
values = values_seq_seq
for key in key_seq:
obj.LocalLB.Class.set_string_class_member_data_value(
for key in key_seq:
obj.LocalLB.Class.set_value_class_member_data_value (
except:
print "Failed to set values for class keys"
################## BEGIN MAIN #########################
import os
import sys
import time
import traceback
import getpass
import pycontrol.pycontrol as pc
from optparse import OptionParser
if pc.__version__.startswith('2.0'):
pass
else:
print "Requires pycontrol version 2.x!"
sys.exit()
parser = OptionParser()
parser.add_option("-b", "--bigip", action="store", type="string", dest="bigip")
parser.add_option("-u", "--username", action="store", type="string", dest="uname")
parser.add_option("-c", "--create", action="store_true", dest="Create")
parser.add_option("-d", "--delete", action="store_true", dest="Delete")
parser.add_option("-l", "--list", action="store_true", dest="List")
parser.add_option("-n", "--classname", action="store", type="string", dest="Class")
parser.add_option("-t", "--classtype", action="store", type="string", dest="ClassType")
parser.add_option("-a", "--addkey", action="store", type="string", dest="AddKey")
parser.add_option("-A", "--addvalue", action="store", type="string", dest="AddValue")
parser.add_option("-r", "--removekey", action="store", type="string", dest="RemoveKey")
(options, args) = parser.parse_args()
if options.bigip and options.uname:
print "Enter your password for username: %s" % options.uname
upass = getpass.getpass()
else:
usage()
sys.exit()
b = pc.BIGIP(
hostname = options.bigip,
username = options.uname,
password = upass,
fromurl = True,
wsdls = [ 'LocalLB.Class'])
if options.Create and options.Class and options.ClassType and options.AddKey and options.AddValue:
print "Creating Class: %s" % options.Class
create_class(b, options.Class, options.ClassType )
print "Adding Entries to: %s" % options.Class
class_members_seq = add_key(b, options.Class, options.AddKey)
print "Adding Values:"
add_value(b, class_members_seq, options.AddValue)
elif options.Create and options.Class and options.ClassType:
elif options.Class and options.AddKey and options.AddValue:
print "Adding Key/Values to: %s" % options.Class
add_key(b, options.Class, options.AddKey )
add_value(b, options.Class, options.AddKey, options.AddValue)
elif options.Class and options.AddKey:
print "Adding Keys to: %s" % options.Class
else:
pass
if options.Delete and options.Class:
print "Deleting Class: %s" % options.Class
delete_class(b, options.Class )
if options.Class and options.RemoveKey:
print "Deleting Entries in: %s" % options.Class
remove_key(b, options.Class, options.RemoveKey)
if options.List:
if options.Class:
get_members(b, options.Class)
else:
print "Getting Full List of Classes"
get_list(b) Published Mar 09, 2015
Version 1.0Alex__Applebaum
Ret. Employee
Joined June 12, 2006
