Java System Info
Problem this snippet solves:
This Java application illustrates how to query system information from a BIG-IP with Java.
This sample is the companion code for the "Getting Started With iControl And Java - Setting Up Eclipse" Tech Tip on DevCentral. It illustrates how to setup the iControl interfaces object and query system information from the BIG-IP with Java and iControl.
Code :
public class SystemInfo {
public iControl.Interfaces m_interfaces = new iControl.Interfaces();
public void usage()
System.out.println("Usage: SystemInfo hostname username password");
public void Run(String [] args) throws Exception
if ( args.length < 3 )
usage();
else
String host = args[0];
String user = args[1];
String pass = args[2];
boolean bInit = m_interfaces.initialize(host, user, pass);
if ( bInit )
getSystemInformation();
public void getSystemInformation() throws Exception
iControl.SystemSystemInformation sysInfo =
m_interfaces.getSystemSystemInfo().get_system_information();
System.out.println("======================================================");
System.out.println(" System Information");
System.out.println("------------------------------------------------------");
System.out.println("System Name : " + sysInfo.getSystem_name());
System.out.println("Host name : " + sysInfo.getHost_name());
System.out.println("OS Release : " + sysInfo.getOs_release());
System.out.println("OS Machine : " + sysInfo.getOs_machine());
System.out.println("OS Version : " + sysInfo.getOs_version());
System.out.println("Platform : " + sysInfo.getPlatform());
System.out.println("Product Category : " + sysInfo.getProduct_category());
System.out.println("Chassis Serial : " + sysInfo.getChassis_serial());
System.out.println("Switch Board Serial : " + sysInfo.getSwitch_board_serial());
System.out.println("Switch Board Part Revision : " + sysInfo.getSwitch_board_part_revision());
System.out.println("Host Board Serial : " + sysInfo.getHost_board_serial());
System.out.println("host Board Part Revision : " + sysInfo.getHost_board_part_revision());
System.out.println("Annunciator Board Serial : " + sysInfo.getAnnunciator_board_serial());
System.out.println("Annunciator Board Part Revision : " + sysInfo.getAnnunciator_board_part_revision());
* @param args
public static void main(String[] args) {
try
SystemInfo sysInfo = new SystemInfo();
sysInfo.Run(args);
catch(Exception ex)
ex.printStackTrace(System.out);
}Published Mar 07, 2015
Version 1.0CodeCentral_194
Joined May 04, 2019
1 Comment
- polakik1234_318
Exception in thread "main" java.lang.NoClassDefFoundError: org/apache/axis/client/Stub
