Interface Failsafe Monitor
Problem this snippet solves:
Another slick solution for a couple of common requirement in high performance environments: To fail over immediately when a physical network connection fails connectivity, or if the number of active members in a trunk falls below the configured minimum.
The first sample supports individual interface monitoring. The second supports the more complex trunk management.
How to use this snippet:
http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=166
Monitor Source: Interface Failsafe only
#!/bin/bash
# (c) Copyright 2007 F5 Networks, Inc.
# Kirk Bauer
# Pass in each interface to monitor via the Arguments field in the GUI
# Collect arguments (first remove IP and port as we don't use those)
shift
shift
interfaces="$*"
b interface show > /tmp/b_interface_show
for i in $interfaces ; do
status=`grep "^ *$i " /tmp/b_interface_show | awk '{print $2}'`
if [ "$status" != "UP" ] ; then
logger -p local0.notice "$MON_TMPL_NAME: interface $i is not up (status: $status)"
exit 1
fi
done
# All specified interfaces are up...
echo "up"
exit 0
Monitor Source: Interface Failsafe w/Trunk Minumum Active Members support
Code :
#!/bin/bash # (c) Copyright 2007 F5 Networks, Inc. # Kirk Bauer# Pass in each interface to monitor via the Arguments field in the GUI. # Each interface may be one of the following: # Physical interface (1.1, 1.2, etc) # Name of a trunk (if at least one interface is up the trunk is considered up) # trunk=min where trunk is the name of the trunk and min is the minimum number # of physical interfaces in the trunk that must be up # For example, the following arguments will make sure that the 1.1 interface is # up and test_trunk has at least two interfaces in it that are up: # 1.1 test_trunk=2 # To test on command-line, use fillers for first two arguments: # /usr/bin/monitors/interface_monitor.sh X X 1.1 1.2 1.3 ... # Collect arguments (first remove IP and port as we don't use those) shift shift interfaces="$*" b interface show > /tmp/b_interface_show for i in $interfaces ; do if grep -q "^ *$i " /tmp/b_interface_show ; then # Physical Interface status=`grep "^ *$i " /tmp/b_interface_show | awk '{print $2}'` if [ "$status" != "UP" ] ; then logger -p local0.notice "$MON_TMPL_NAME: interface $i is not up (status: $status)" exit 1 fi else # Not a physical interface, assume a trunked interface trunk="$i" reqcount=1 if echo "$trunk" | grep -q '=' ; then trunk="$(echo "$i" | sed 's/=.*//')" reqcount="$(echo "$i" | sed 's/^.*=//')" fi upcount=0 for status in `grep "$trunk" /tmp/b_interface_show | awk '{print $2}'` ; do [ "$status" == "UP" ] && upcount=$[$upcount+1] done if [ $upcount -lt $reqcount ] ; then logger -p local0.notice "$MON_TMPL_NAME: trunk $trunk is down (has only $upcount active interfaces, $reqcount required)" exit 1 fi fi done # All specified interfaces are up... echo "up" exit 0
4 Comments
- Cirrus
Cirrus
You can change the bigpipe command "b" to tmsh:
tmsh show net interface > /tmp/tmsh_interface_show
- dyobbs_25515
nice kirk, do you have such code that monitors the bandwidth interface?
- computerli
Altostratus
Anyone know how to get the trunk status in version 13 ?
- computerli
Altostratus
b interface show ?
