tal221_177749
Feb 17, 2015Using RDS 2012 With UDP Enabled
I have Microsoft RDS 2012 and i create "Virtual Server" Evereting is Working but i can't choose UDP and TCP i can only choose one of them and not both
[IMG]http://i57.tinypic.com/2ag7sz4.png[/IMG]
for that RDP to work with UDP Enabled i need to make F5 to work with UDP and TCP how do i do that? irule maybe? i am using Big-IP 10.1
- nathe
Cirrocumulus
tal221, can you either create 2 virtual servers, both same ip/port but one with UDP as the protocol and the other with TCP? or do you have an option in your version to select All Protocols?
Hope this helps,
N
