rpalacios_79340
Altostratus
Jan 27, 2010Trunk setup for Cisco 6509 and F5 ltm 1600
Hello guys,
I've finally reached a point in my environment where I THINK I may need to setup a trunk between 2 Cisco 6509 core switches and 2 F5 ltm's (paired).
Currently my ltm's are in a mesh config connected to both 6509's. All ports in the 6509 are configured as access ports and belong to an app vlan and dmz vlan.
So I have been creating pools on these vlans without any issues as they are directly connected.
The problem: We have multiple vlans in our environment and now we have a need to load balance mysql servers which reside on a vlan that is NOT directly connected to the F5's. Meaning that the self ip's are configured for our app's and dmz vlans.
It sounds logical to me to setup a trunk between the F5's and the 6509's and allow all required vlans for future load balancing needs.
1. Are there any know issues I need to be aware of when I introduce the trunk?
2. What is the best mesh config? Should ltm-A go to 6509-A and ltm-b go to 6509-b?
3. Are there any known issues with looping, spanning tree, etc?
4. What would be the recommended settings for LACP?
5. Is there a better method?
All is appreciated!
Thanks,
-rp
- Hamish
Cirrocumulus
Posted By rpalacios on 01/27/2010 11:05 AM
Well... You need to be aware that F5 and Cisco people talking need an interpreter between them.
Cisco Trunks == F5 VLAN Tagging
Cisco Etherchannel == F5 Trunks
Assuming (From the description) you mean cisco trunks/f5 vlan tagging, then no there's no real problems. I usually set the allowed vlans on the cisco however when doing this.
That's the way I doit. Primarily because I also use etherchannels (F5 trunks) to connect for aggregated bandwidth. On cisco's you can't make a channel ACROSS switches.
Yeah. F5's can be switches. Don't set portfast on the cisco. I usually use STP passthrough on the F5. This is more relevant where you have bridged VLAN's not F5 trunks/etherchannel.
I use
channel-group mode active
on each interface.
Well... You could probably come up with a different method each day... Whether they're right would depend on your requirements. I know mine works, and passes all the tests thrown at it.
H - Nick_T_68319
I run a similar setup with 6509's and LTM pairs. LTM-A goes to 6509A and LTM-B goes to 6509B. I use the two fiber modules in an LACP group, and trunk the vlan's to the LACP group. - rpalacios_79340
Altostratus
Thanks for the replies guys.
Is there any reason why you wouldn't use one interface on each f5 to one 6509 and the other to the second 6509 and configure them as individual trunks?
I like the one to one relationship, but I would like to explore all possibilities.
I tried attaching a drawing under 100kb but kept getting an error.
Thanks again,
-rp - Nick_T_68319
Well you won't be able to LACP them, and i think you may run into spanning tree issues there since your A and B switch are probably running different spanning tree priorities, but i am not a network expert. I think if you had one interface to each, you have to set the priority lower on one, to force traffic through one interface when it is up. - Hamish
Cirrocumulus
Spanning tree will sort itself out, AS LONG AS you have STP passthrough configured (Or if you know networks you could have the F5 do STP as well. But that's not always a simple config. You want to make sure you know exactly what's going to happen with your root bridge in all situations.
However you WILL get spanning tree reconvergences when doing this. Which means each VLAN (Assuming you're doing VLAN'ed spanning tree), every time you restart an F5. WHich isn't nice (30 second pause in the VLAN).
I like to avoid spanning tree whenever possible.
Oh... Don't try to get around the spanning tree by setting portfast... The F5 acts as a bridge. Portfast isn't a good idea through a bridge.
H
