aj11's avatar
aj11
8 years ago
Troubleshooting AOM management interface
How do I view current AOM network settings? The AOM port is not coming up after re-configuring several times. Also, how do I cleanly exit AOM on the 6900 platform?
  • Hi,
    you can connect to AOM subsystem from BigIP system.
    in bash:
    ssh aom
    with this access, you can reconfigure AOM.
  • while the
    ssh aom
    works and it documented i believe it is a bit of a workaround (they took ik away in the 2000/4000 and iSeries), have you tried via the console port?
    what do you mean with the AOM port doesn't come up? it is combined with the mgmt port, is that up?
