Sayan_81841's avatar
Sayan_81841
Feb 24, 2011
Switch statement not working
I wrote an iRule and the content is given below. But this is not working as expected.
if { [HTTP::host] starts_with "abc.com" } {
set var1 "/abc/xyz"
set var2 "/xyz/abc"
switch -glob [HTTP::uri] {
$var1 {
HTTP::redirect "http://www.google.com"
$var2 {
HTTP::redirect "http://www.yahoo.com"
concat $var1 "mail" {
HTTP::redirect "http://mail.yahoo.co.uk"
default {
The compilation is successful and no syntax error but the redirections are not happening and always showing "Page not found". But when I converted the above iRule to if elseif statement it started working.
Please let me know what is the issue with the iRule.
  • hoolio's avatar
    hoolio
    Hi Sayan,
    The curly braces at the beginning and end of the switch statement prevent variable expansion. See this thread for an alternative:
    http://stackoverflow.com/questions/3261515/tcl-switch-glob-does-not-match-with-variable
    when RULE_INIT {
    set var1 "test1"
    set var2 "test2"
    switch -glob -- "test1mail" $var1 {
    log local0. "matched $var1"
    } $var2 {
    log local0. "matched $var2"
    } "${var1}mail" {
    log local0. "matched ${var1}mail"
    } default {
    log local0. "no match"
    : matched test1mail
    Aaron
  • Yes, I came into that a while back when writing a tech tip. You can omit the curly braces and use a line continuation character to make the switch statement a single line. Otherwise, I haven't found any workaround to this.
    -Joe
