F5Hopper_28651
Sep 20, 2012string tolower? and HTTPS redirects
I have a few rules like this..
if { [HTTP::uri] eq "/Recovery.aspx" } {
HTTP::redirect "https://qa.www.google.com/Recovery.aspx"
if { [HTTP::uri] eq "/Signup.aspx" } {
HTTP::redirect "https://qa.www.google.com/Signup.aspx"
my issue is if I use a string tolower command it doesnt redirect to https://, Im trying to make it so the users changes the URL to /signup.aspx that it also redirects to HTTPS://
my other question is can I group these rules together?
- Mohamed_Lrhazi
Altocumulus
Merge the two iRules by simply moving on 'if" block into the othe rule.
You should post the code of your iRule does not work, so people can see how you are using the tolower function. - F5Hopper_28651
ok thanks I have made my rule and its working now.
if { [string tolower [HTTP::uri]] eq "/application.aspx" } {
HTTP::redirect "https://qa.www.google.com/Application.aspx"
if { [string tolower [HTTP::uri]] eq "/customerportal.aspx" } {
HTTP::redirect "https://qa.www.google.com/Login.aspx"
if { [string tolower [HTTP::uri]] eq "/login.aspx" } {
if { [string tolower [HTTP::uri]] eq "/recovery.aspx" } {
if { [string tolower [HTTP::uri]] eq "/signup.aspx" } {
if { [string tolower [HTTP::uri]] eq "/activateaccount.aspx" } {
HTTP::redirect "https://qa.www.google.com/ActivateAccount.aspx"
it ended up that in my-
I had used the real URI of "/ActivateAccount.aspx", this line needed to be lowercase in order to work.
Now is there any way of making the HTTP::redirect more generic? so I can use it for other sites in DEV...so https://dev1.www.google.com?
