GMB_10's avatar
GMB_10
Jan 12, 2021
Stop Edge Client auto prompt for re-login, after tunnel time-out
Many of our remote users keep their tunnels up and let them self time-out. After a Time-out, the tunnel is disconnected and the edge client will auto prompt for username and password credentials using the popup login page.
Can I prevent auto popup of the login page after time-out, as in it would just disconnect the tunnel (just like clicking disconnect) ?
  • Hello, that is the default behavior and can not be changed as far as I can tell. I think there might be a Feature Request for something like this.
