Smart way to convert a PoolMemberDefinitionSequenceSequence to a IPPortDefinitionSequenceSequence
I want to dump out (and eventually read in and set) the enabled state of each of my GTM pools pool members. Its easy to get a list of the pools and pool members, but the PoolMember.get_enabled_state requires input parameters of the pools (simple) and a Common.IPPortDefinitionSequenceSequence. I'm having trouble figuring out the best way to programmatically get an IPPortDefinitionSequenceSequnce to pass in.
I have a PoolMemberDefinition named poolmembers loaded as follows:
wideips = wipobj.get_list()
pools = poolobj.get_list()
poolmembers = poolobj.get_member(pools)
I want to get the enabled state of each of the poolmembers. I should be able to loop through the poolmembers object and strip out each poolmember address and port and save it to another object (which would then be of type IPPortDefinition), but is that the best way?
thanks,
andy
- L4L7_53191NimbostratusOk - this should get you close. My brain is a bit fried so there are probably more optimizations available. Note that I added the little stub class just for some sane data structures that we can access via attributes. This is probably slower than other methods, but to me it's cleaner...
wipobj = b.GlobalLB.WideIP poolobj = b.GlobalLB.Pool poolmemobj = b.GlobalLB.PoolMember wideips = wipobj.get_list() pools = poolobj.get_list() poolmembers = poolobj.get_member(pools) class DataHolder(): ''' A dummy class to set attrs against for ease of reading ''' def __init__(self, tup): self.pool = tup[0] self.members = self.clean_members(tup) self.member_states = [] def clean_members(self, tup): return [x.member for x in tup[1]] combined = zip(pools,poolmembers) data_list = [] print out pool name, and its members. for x in combined: data_list.append(DataHolder(x)) print "Pool: %s" % x[0] print "\t Mems:" for y in x[1]: print "\t=>%s:%s" % (y.member.address,y.member.port) Now, we've got the IPPort definitions already defined, per pool found inside the data_list[idx].members attribute. We can pass that array into a Commoon.IPPortSequence.items[] array and get the status. pmemseq = poolmemobj.typefactory.create('Common.IPPortDefinitionSequence') pmemseq.item = [x.members for x in [y for y in data_list]] member_status = poolmemobj.get_enabled_state(pool_names = [x.pool for x in data_list], members = [pmemseq])
- I will post it for sure. thanks for your help!
- i don't really understand the shortcuts you've taken with the for loops here:
- L4L7_53191NimbostratusHave a look at 'list comprehensions'. They're extremely handy in situations like this. Think of them as an easy way to create a list from another iterable after you've manipulated it in some way. Similar to map(). So expanded, this:
- mytestpool1 is the first pool in the list (e.g. data_list[0].pool) and its members are 1.1.1.1:80 and 1.1.1.2:80
Note - i edited this post after some investigation/testing.
it looks like the pmemseq is really a flat list- If it was an IPPortDefinitionSequence, shouldn't i be able to access each object using an index?
i.e. using my pool examples from above shouldn't i be able to do this:
pmemseq[0][0].address ?
instead i get an error:
In [316]: pmemseq[0][0].address
IndexError Traceback (most recent call last)
C:\Windows\system32\ in ()
IndexError: string index out of range
if i just dump out pmemseq it does contain data, but I can't seem to get to it via indices as i would expect:
In [326]: pmemseq
Out [326]:
(Common.IPPortDefinition){
address = "10.1.1.1"
port = 80
address = "10.1.1.2"
port = 80
address = "10.1.2.10"
port = 80
address = "10.1.2.11"
port = 80
- L4L7_53191NimbostratusYes, there's an ordering bug somewhere. I've got a few minutes to test at lunch, will post back what I fiind. The first call is accurate:
- a side question - is there an append or similar method to the .item call of an object (e.g. IPPortDefinitionSequence)? I'd like to loop through and add objects to the sequence one at a time. or do you have to build the whole list first and then assign? (which is the only use case i've seen in examples)
- L4L7_53191NimbostratusTo answer the side question: the items[] thing is simply an attribute you set against the sequence objects. It coerces suds into setting up the xml correctly to pass in a list of ojects. Any Sequence item (as opposed to sequencesequence) requires that this attribute is set. It's just a normal list, so any list method will work - append, index lookups, etc.
- brilliant! yes that works perfectly. and it was the 'sequence_factory' piece that was outside of my mental grasp. thank you very much for all your help!
