Mike_McCardle_1
Jan 03, 2007Simple Drop rule help
I have the following iRule applied to one of the Virtual servers on my F5, and what I wanted it to do was accept traffic only on the specified ports, and all other requests to drop the packets. when I run NMAP against the IP address, it shows a large amount of ports open. The Virtual server does accept all ports, but it has the iRule applied.What am I doing wrong? Thanks.
when CLIENT_ACCEPTED {
if {([TCP::local_port] >= 6000 ) && ([TCP::local_port] <= 6299) ||
([TCP::local_port] >= 177 ) && ([TCP::local_port] <= 177) ||
([TCP::local_port] >= 21 ) && ([TCP::local_port] <= 21) ||
([TCP::local_port] >= 389 ) && ([TCP::local_port] <= 389) ||
([TCP::local_port] >= 48140 ) && ([TCP::local_port] <= 48144) ||
([TCP::local_port] >= 2148 ) && ([TCP::local_port] <= 2148) ||
([TCP::local_port] >= 13131 ) && ([TCP::local_port] <= 13131) ||
([TCP::local_port] >= 22 ) && ([TCP::local_port] <= 22) } {
pool SD4_Mgmnt
} else drop
- bl0ndie_127134Historic F5 AccountCLIENT_ACCEPTED is fired after the 3 way handshake is completed, in another words when a connection is established.
- hoolio
I haven't tested this, but I wonder if you could use packet filters to drop the connection before the TCP handshake is complete for destination ports you don't want the VIP to answer on.
Click here
Aaron
