blacksan_10396
Dec 07, 2006SDK 5.0 Samples against FP 6.0
My developers are looking at the SDK and having problems getting the Favorites to show after authentication. I decided to start from scratch and use only the samples on the SDK download and get the same error. This is how it is configured:
Open SDK Example with Microsoft IE 6 = AppTunJS.htm
Allow Active-X component
Host: / = demo.com/demo
Port: 443
Username: test
Userpassword: test
Click Login
Status gets last shows this before pop-up error:
Session: https://demo.com/vdesk/index.php3
Pop-up error:
Microsoft Internet Explorer
Cannot get list of favoritesCannot obtain list of favorites
OK
Firepass configuration:
Version 6.0 with HF8
Master Group: Demo_master
-Authentication=Local
-Resource: Demo_resource
Network Access Name: Netaccess
I ran HTTPWatch to see the transactions and notice two things:
***Get Request after POST User Authentication:
GET /blankmy.activation.cns.php3?langchar=en.iso-8859-1&ui_translation=off&refreshURL=/vdesk/?langchar=en.iso-8859-1&ui_translation=off&gbrowsertype=&tryonce=1 HTTP/1.1
404 Not Found
404 Not Found
The requested URL was not found on this server.
***Next Get Request:
GET /vdesk/geekster/index.php3?id=uroam_mngeekster&S=92a6b25590f8bef60e94a72896609ee4&outform=xml HTTP/1.1
- blacksan_10396
OK, I found out why Network Access was not working with the original SDK 5.0 samples and my configuration. It was trying to look for a APPTUNNEL instead of VPN in the code.
So to get Network Access, open code and perform a Find/Replace on APPTUNNEL for VPN. So now that works, I can move on. Next step is trying to figure out why Application Tunnels (Terminal/Static/Dynamic) does not work using the API.
Later, providing End-Point Inspection information like Anti-virus stuff to the F5 Firepass Controller from the API for Pre-Login/Protective Configuration (really doubt it but worth looking into). Or see if Pre-Login Inspection can detect the API like the Stand-alone client upon login.
