Simon_Gregory_1
Jan 22, 2007Redirect Help (but NOT over HTTP) !
I have two LTM's on two physical sites (site A & B). I intend to install an iRule on the LTM (site A) to direct specific traffic originating from a specific source. This traffic will be directed to a Virtual Server installed on a different LTM (on site B). The application is not using the HTTP/S protocol.
when CLIENT_ACCEPTED {
Checks to see if remote_addr = any in the 'source_ip' class
if { [matchclass [IP::remote_addr] equals $::source_ip] } {
Route the connection to the remote Virtual Server (10.x.x.x:41475)
which is managed by a different remote LTM
???????????????????? 10.x.x.x:41475
else {
Send the connection to the local Pool on the local LTM
pool local_pool
Thanks, Simon (UK)
- AaronJBRet. EmployeeMy initial thoughts here are that the easiest way to accomplish this is to create a second pool on LTM A, which contains a single entry - the VIP IP on LTM B.
Then in your iRule you can simply select the other pool.
The downside of this is that you will be 'double processing' all the rerouted requests, as they will be passing through both LTM A, and LTM B (it also assumes that LTM A can access LTM B).
Otherwise being able to redirect traffic in the same way you can with HTTP would rely on the particular protocol you are passing having some kind of 'Please see this resource instead:' message type that you could reply to the original request with.
If that is the case then you could construct your own response to the message with the TCP::respond command - let me know if you are looking to achieve that (and what the message structure is for the protocol you are using, if you need an explicit example).
Aaron - Simon_Gregory_1
Hi Aaron,
Thanks for the response.
I had not thought of creating a new pool. The solution is simpler than I thought.
Regards, Simon - Mike_Graston_10
I had done something similar to this where as I needed to snat the incoming address so it would pass through the 1st F5. then the remote node/vip/IP would then route back through the original f5. Not sure of your Network topology but something to consider as you probably don't want an asymetric route.
