jon_monts_46033's avatar
jon_monts_46033
Feb 07, 2012
Pycontrol 2 - issue disabling nodes
Created a script via python to disable nodes, and nodes are not being disabled. Script & log included. Any suggestions would be apperciated.
Script:
import sys
import pycontrol.pycontrol as pc
import time
import csv
import logging
logging.basicConfig(level=logging.INFO)
logging.getLogger('suds.client').setLevel(logging.DEBUG)
b = pc.BIGIP(
hostname = 'xx.xx.xx.xx',
username = 'xxxxx',
password = 'xxxxx',
fromurl = True,
wsdls = ['LocalLB.NodeAddress'])
def enable_node():
enable_disable_node('STATE_ENABLED')
def disable_node():
enable_disable_node('STATE_DISABLED')
def enable_disable_node(target_state):
nodes = 'xx.xx.xx.xx'
states = []
states.append(target_state)
b.LocalLB.NodeAddress.set_session_enabled_state(node_addresses=nodes, states=states)
disable_node()
Respose:
DEBUG:suds.client:sending to (https://xx.xx.xx.xx/iControl/iControlPortal.cgi)
message:
xx.xx.xx.xx
STATE_DISABLED
DEBUG:suds.client:headers = {'SOAPAction': u'"urn:iControl:LocalLB/NodeAddress"', 'Content-Type': 'text/xml; charset=utf-8'}
DEBUG:suds.client:http succeeded:
DEBUG:suds.client:sending to ()
message:
http://schemas.xmlsoap.org/soap/encoding/" xmlns:ns0="urn:iControl:LocalLB/NodeAddress" xmlns:ns1="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns2="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
xx.xx.xx.xx
STATE_DISABLED
xmlns:E="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:A="http://schemas.xmlsoap.org/soap/encoding/"
xmlns:s="http://www.w3.org/2001/XMLSchema-instance"
xmlns:y="http://www.w3.org/2001/XMLSchema"
xmlns:iControl="urn:iControl"
E:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
xmlns:m="urn:iControl:LocalLB/NodeAddress">
  • your code appears to work for me, however, the monitor state and the session state need to be disabled. Also, this interface is deprecated, so if you are on v11+, please use the NodeAddressV2 interface instead.
    >>> na = b.LocalLB.NodeAddress
    >>> def enable_node():
    ...     enable_disable_node('STATE_ENABLED')
    >>> def disable_node():
    ...     enable_disable_node('STATE_DISABLED')
    ...     nodes = ['10.10.10.10']
    ...     states = []
    ...     states.append(target_state)
    ...     na.set_session_enabled_state(nodes=nodes, states = states)
    ...     states = []
    ...     na.set_session_enabled_state(node_addresses = nodes, states = states)
    ...     na.set_monitor_state(node_addresses = nodes, states = states)
    >>> enable_node()
    >>> na.get_monitor_status(node_addresses = ['10.10.10.10'])
    [MONITOR_STATUS_UNCHECKED]
    >>> na.get_session_status(node_addresses = ['10.10.10.10'])
    [SESSION_STATUS_ENABLED]
    >>> disable_node()
    [MONITOR_STATUS_FORCED_DOWN]
    [SESSION_STATUS_FORCED_DISABLED]
  • Jason, I was doing disabling both in a prior example and removed the monitor state since I thought there was something wrong with my code. I used the NodeAddressV2 and it is now working. Thanks for the help.
    ~Jon
