trx's avatar
14 years ago
pool check numeric values
Hello Community,
I'm trying to determine what each numeric value means when checking a pool's state.
ex)
3) iRule3->VS3:
if { ([active_members pool1] < 1) or ([active_members pool2] < 1) or ([active_members pool3] < 1) } {
pool pool6
pool pool3
What does the " < 1 " actually mean? What other numeric values are there and what do they mean?
Thanks in advance.
Regards,
TRX
  • Steve_Brown_882's avatar
    Steve_Brown_882
    Historic F5 Account
    The example you show is checking the number of active pool members so <1 would mean all of the pool members are down.
  • Would happen to know what the numbers below mean?
    1, 2, 3, etc?
    ex) Goal is to check if the pool member specified is flagged down/disabled or NOT
    if { ([pool google-search member 192.168.254.189 80] < 1) } {
    pool google-search member 167.3.11.93 7800
    return
    pool google-search member 167.3.10.93 7800
    return
    Thanks.
    Regards,
    TRX
  • If you want to check the status of a node you can use the LB::status command.
    http://devcentral.f5.com/wiki/iRules.LB__status.ashx
    Your iRule would look something like this:
    log local0. "Node 1 Status:  [LB::status pool my.pool.name member 10.10.10.10 80]"
    log local0. "Node 2 Status:  [LB::status pool my.pool.name member 20.20.20.20 80]"
    if { [LB::status pool my.pool.name member 10.10.10.10 80] eq "down" } {
    HTTP::redirect "http://www.yahoo.com"
    if { [LB::status pool my.pool.name member 20.20.20.20 80] eq "down" } {
    HTTP::redirect "http://www.msn.com"
