PKI PIN works for users from one network, not the other.
We have external users and internal users accessing a virtual server.
It's fronted by an APM policy, that asks for the DoD PKI/pin, does an OCSP check, LDAP check, and then sends users on their way to LTM. (there's no SSO, or anything involved)
When being load balanced to the application, the end application prompts the users for their PKI/PIN at the app again for access.
For the internal network users, this works.
For the external network users, their PIN is not being accepted.
Is there something I'm missing on the F5 side of things? I even disabled APM for that FQDN through the VS and it still has the same result.
- Kevin_Stewart
Employee
Late to the party, but does traffic break for external network users? Is decryption/re-encryption configured anywhere? For mutual TLS (client cert auth) you cannot decrypt the traffic at the proxy if the backend server requires the client certificate. At a high level, a mutual TLS handshake requires the client to generate a hash (signed by its private key). If the traffic is getting decrypted anywhere in that path, the re-encrypting device would not have access to the client's private key to correctly generate that hash.
The one exception to the above is when using C3D on BIG-IP (client certificate constrained delegation). This feature allows you to explicitly decrypt mutual TLS client traffic on the client side, and then forge a client certificate to the server on the back side.
Hello,
I see your post has been up for some time without any response. Outside of the steps you have already taken, if you have not resolved your issue I would suggest creating a case myf5 (if you have support) for one of our support engineers to assist.
If you have already found a resolution we would appreciate you update your post and provide what steps you took. This will help future users of our community who may run into the same issue.
-Melissa
