John_Gruber_432's avatar
John_Gruber_432
Historic F5 Account
Jul 30, 2011
Node Default Monitor
I can add the Node Default monitor(s) by using the set_monitor_association on the NodeAddress object with ATYPE_STAR_ADDRESS for the address type with "*" set for the IP address.
I tried removing it by using remove_monitor_association with the same monitor ip settings. It takes FOREVER to return (like 20 seconds) and then doesn't do anything..nor error.
Can someone tell me definitively how I'm supposed to remove the Node Default monitor with iControl?
