NGINX reverse proxy authentication module with DUO
Dears,
I need to publish on-prem Tableau server so i have 2 nginx plus reverse proxies servers and DUO for SSO and MFA so How can i enable 2FA on the DMZ environmet using nginx reverse proxy? Is there is any authentication module or anything suppose to help me?
Thanks BTW,
Ussama
Maybe try the e NGINX example for Okta and other such systems with OAuth/OpenID Connect as a way (Nginx now also has SAML support but better follow the official example with OAuth). Did you try it?
https://docs.nginx.com/nginx/deployment-guides/single-sign-on/
- Leslie_HubertusRet. Employee
Hi ussamaabdulrahman - I see that nobody has replied yet, so I'm going to pin your question to increase visibility to the community. Not sure if buulam may have some insight here?
