kend
Altostratus
Apr 15, 2009Monitoring Link Stats using F5-BIGIP-GLOBAL-MIB
I have a set of link controllers running software version 9.3.0 and I want to monitor the link stats using SNMP. I have the mib files loaded in my SNMP application and when I try to get gtmLinkStatRate from within F5-BIGIP-GLOBAL-MIB, but it always responds with "Request failed or timed out. No error". I tried a different SNMP application to get gtmLinkStatRate, and it failed as well. Do the link controllers support getting this SNMP OID? I basically want to get bandwidth usage in Mbps for my two ISP links.
- hwidjaja_37598
Altostratus
Check the SNMP's community string and access list setting on the LC and make sure firewall is not blocking SNMP traffic.
Run this command from the LC:
snmpwalk -v2c -c localhost gtmLinkStatRate
or
snmpwalk -v2c -c localhost .1.3.6.1.4.1.3375.2.3.5.3.3.1.2
If it worked, try it from the managing server, e.g.
snmpwalk -v2c -c gtmLinkStatRate
If it didn't work, check the community string, access list or firewall.
