Brian_Moore_603's avatar
Brian_Moore_603
Oct 24, 2008
Monitor and pull a node
Howdy,
I've looked this forum and I can't seem to find something I need???
I am looking to monitor the CPU of a web server (which is being load balanced in a pool) and when the CPU gets to a certain point pull the web server out of the pool? I see where people are using SNMP and WMI for some of this but for whatever reason those monitors according to the manual are for "weighted" load balancing? I want to use a non specific load balance (round robin) and just have the f5 pull the server when CPU gets to a certain point. Anyone got any ideas how to solve this puzzle?
Melloyellow
  • hoolio's avatar
    hoolio
    You could build an external monitor which only returns up if the script finds the server CPU usage below a defined threshold.
    You can find example external monitors in the Codeshare:
    Advanced Design & Config CodeShare (Click here)
    Aaron
