Match content in HTTP request and response - and block if value does not match
All, Been asked to implement a temporary fix for a web site until the server side fix can be written. The need is to query a soap POST request coming in to a web site on a specific URI, decode the authentication header in the request and perform a look up in a datagroup to find a mapped value, and match the web service call in the body of the POST request. If the request is one of the calls needing to be filtered then inspect the response back from the server and match a string in it to ensure it contains the mapped value from the datagroup, and if not block the server response.
I have the inbound working fine and set a variable "fixwc" if the inbound request matches the web service call that needs to be match and the "orgstring" variable as the string to match in the response, however the match on the server response using HTTP::collect does not work and appears if I write the payload to the log file to be only the first few lines of the response. I have adjusted the irule to use stream which does match successfully but I cannot see how to block the response if the string does not match.
Below is the snippet from the irule with the stream match -- can anyone advise if there is a way to stop the response being sent to the end user if the stream does not match or do I need to go back to HTTP:collect and try to work a way to capture the full server response?
check server response contains matching orgstring otherwise drop request
when HTTP_RESPONSE {
STREAM::disable
if {$fixwc eq "1"} {
if { [HTTP::header value Content-Type] contains "text" } {
STREAM::expression @$orgstring@
STREAM::enable
if match allow request - else block response
when STREAM_MATCHED {
log local0. "Temp fix-irule OrigID correct for request -- [STREAM::match]"
For reference this was the section using HTTP:collect
Trigger collection for up to 1MB of data
if {[HTTP::header exists "Content-Length"] and [HTTP::header "Content-Length"] <= 1048576}{
set content_length [HTTP::header "Content-Length"]
set content_length 1048576
Check if $content_length is not set to 0
if { $content_length > 0} {
HTTP::collect $content_length
when HTTP_RESPONSE_DATA {
if { [string match $orgstring [HTTP::payload]] } {
log local0. "Temp fix-irule matched OrgString - allowing response)
return
else discard
log local0. "Temp fix-irule failed to match OrgString - dropping response"
- MW1
Cirrus
I should just advise with regards to my comment "if I write the payload to the log file to be only the first few lines of the response" I have just read that the local log output is limited to the first ~1000bytes - using the HTTP Payload as a HTTP response in the irule when the match fails I do see the string in there, so the approach using HTTP::collect and match string issue appears to be simply the match command is not reading further enough down the response...totally confused currently!
- MW1
Cirrus
Managed to resolve myself - Just to advise found I needed to switch
if match allow request - else block responsewhen HTTP_RESPONSE_DATA { if { [string match $orgstring [HTTP::payload]] } { log local0. "Temp fix-irule matched OrgString - allowing response) return }{ else discard log local0. "Temp fix-irule failed to match OrgString - dropping response" } } `To be :` if response data contains match allow request - else block response when HTTP_RESPONSE_DATA { if { [HTTP::payload] contains $orgstring } { HTTP::release log local0. "Temp fix-irule match HomeOrg $homeorg to EnterpriseOrg $orgstring allowing request" } else { HTTP::respond 500 content BLOCKED log local0. "Temp fix-irule HomeOrg $homeorg to EnterpriseOrg $orgstring does not match -- dropping request" } }
